 ^Click to View Caseman's Pics^ |
Antique Tractors Forum Pictures & Discussion Of Antique Tractors & Machinery Owner & Administrator: Caseman Administrator: nyfarmerguy
| View previous topic :: View next topic |
| Author |
Message |
ky wonder Member
Joined: Jun 24 2007 User's Age: (55) Posts: 98 Location: horse cave, ky member # 294
Posted: Tue Dec 08, 2009 9:50 pm Post subject: 60 clutch noise |
my old 60 has started making a racket when the clutch is not engaged ,
it makes a rattleing sound that is not constant but pulses, as it sits,
it does not do this all the time but is getting to be more regular, it is guiet when engaged, and is still pulling okay, but it is at the end of its adjustment range. and i know it will need new disk, but i was wondering if i should go ahead and order any other parts besides the new disk and sping set s before i tear it down
thanks for your help _________________ i like things that go pop/pop |
| Back to top |
alabamafrog Member 250 club
Joined: Feb 04 2009 User's Age: (35) Posts: 273 Location: Decatur/Huntsville AL
Posted: Tue Dec 08, 2009 11:00 pm Post subject: |
It is relatively easy to tear it down and put it back together. If it were me I’d take it apart and check everything before ordering any parts. You will need to make a puller for the driver, I have a ½” plate with a hole in the center and slots on each end, it worked great for mine. Tightened it up then hit the center bolt with a hammer and the driver popped right off. Some things to watch out for, make sure the driver gets good and tight on the crank at least 1/8” before the crank is flush. When you remove the center bolt make sure the driver is sticking out past the crank, 1/8” will do but ¼” is better. Make sure to align the driver with the crank marks. May want to make sure both the driver and the crank are marked before disassembly.
I have never noticed any noise on mine but I’m careful not to let the clutch stay disengaged for more than a few seconds before I just put it in neutral and reengage. _________________ ***My Tractor Pics***
Mine
1947 JD A
1948 JD A
1951 JD MT
1956 JD 60
2000 JD 4700
Dads
JD 4010D
JD 4020D
JD 3020D
JD 1010
JD 4430
IH 856 custom
Ford 9600
Ford 8N
Belarus 405AN |
| Back to top |
Jordan Bergsma Active Moderator
Joined: Dec 06 2008 User's Age: (15) Posts: 387 Location: Ontario member # 1592
Posted: Wed Dec 09, 2009 3:07 am Post subject: |
Could be the throwout bearing. Thats whats wrong w/ my Oliver 77, and it makes grinding and rattling noises as well. _________________ -Jordan
-Christian Farmer-
1950 Oliver 77 Rowcrop.
Nuffield 4/65 |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
DISCLAIMER: AntiqueTractorsForum.com permits you to have access to the contents of this website but you acknowledge that your use of that content is governed by applicable copyright, trademark or other intellectual property law and agree that the content of this site may not be copied for commercial use or distribution, modified or re-posted to other sites.
Powered by phpBB © 2001, 2005 phpBB Group
