| Author |
Message |
Peterbilt Member
Joined: Aug 31 2008 User's Age: (25) Posts: 247 Location: Sandusky, Ohio member # 1341
Posted: Sat Jan 09, 2010 9:29 pm Post subject: Restoring 49 VAC |
Well I decided start redoing my favorite tractor I have. Since now that I have a lot of nothing else better to do.
That the progress I made so far. She may look pretty in the picture but the person I bought it from threw a quick paint job on it about 10 or so years ago. Im going to sand blast it back down to bare metal and start fresh. I do have to split it to replace the gears on the fly wheel. I'll keep updating as I go. _________________ 1940 Ford 9N
1952 Ford 8N
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC
1946 Case VAC |
| Back to top |
1031D Subscriber & Active Moderator
Joined: Mar 11 2008 User's Age: (30) Posts: 1010 Location: Wisconsin member # 935
Posted: Sat Jan 09, 2010 11:12 pm Post subject: |
Looks like a good start to me! Was wondering what is up with the center lift parts from the old style hydraulics with the eagle hitch?? Do you need a ring gear? _________________ Jim
Lot's of Quality CASE Equipment used and serviced here! |
| Back to top |
petra79 Subscriber & Active Moderator
Joined: Aug 12 2007 User's Age: (49) Posts: 3723 Location: N.W. Indiana
Posted: Sat Jan 09, 2010 11:49 pm Post subject: |
Looks to be coming apart just fine. Keep the pictures and updates coming. _________________ Ron
1958 - Ford 861 Powermaster
1979 - A/C 712 Shuttle
1974 - A/C 712 Shuttle
Little Genius #8 single 16" on steel |
| Back to top |
Peterbilt Member
Posted: Sun Jan 10, 2010 1:27 am Post subject: |
| 1031D wrote: | | Looks like a good start to me! Was wondering what is up with the center lift parts from the old style hydraulics with the eagle hitch?? Do you need a ring gear? |
Theres two seperate hydrolic systems on it. I put the old style on it to use other types of impliments. As for the ring gear, the one thats on it is missing a bunch of teeth (it wasnt me that did it). I am looking for one, Steiner has new ones for 75 bucks.
Also when I change gears, I have to throttel all the way down or it will grind. My old 44 or my 46 dont do it. I was told that it has to do with my gears bot being singroed(sp) or something in that nature. How hard will it to be fixed? _________________ 1940 Ford 9N
1952 Ford 8N
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC
1946 Case VAC |
| Back to top |
Posted: Sun Jan 10, 2010 7:21 am Post subject: |
Sounds like something else, there are no syncro rings in that tranny. Sounds like maybe your clutch is not releasing all the way. I might have a good ring gear on a flywheel. I also might have a spare clutch too! All 4 of my VAC's do not grind when shifting unless you are moving. While you are going that far, also check the torque tube bearings as they are almost always bad or out of adjustment. _________________ Jim
| Back to top |
Peterbilt Member
Posted: Sun Jan 10, 2010 3:52 pm Post subject: |
When the power is all the way down, I can shift in and out easily. But when I stop to shift and it still in gear, I can quickly shift to the next gear. It just like grind when its in neutral and shift into a gear. It can really irk me sometimes. Ill check the clutch when I get to that part. As for the ring gear, How much would you want for it? _________________ 1940 Ford 9N
1952 Ford 8N
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC
1946 Case VAC |
| Back to top |
Posted: Sun Jan 10, 2010 8:09 pm Post subject: |
If it's any good(memory fuzzy right now) and I can get it off, or sell you the whole thing, I suppose $30 plus shipping. I did some thinking and some tinkering, and I think your problem is the pilot bearing in the end of the crank, might be chewed up and grabbing the input shaft. _________________ Jim
| Back to top |
Peterbilt Member
Posted: Tue Feb 02, 2010 3:35 am Post subject: |
Took my engine apart a few weeks ago and when I drained the oil I got alot antifreeze that came out with the oil. So I took the head off to see what the cause and my father found two cracks. From the dash forward the are between the first three cylinders D O-O-O O . The dash marks is where the cracks are and they go all the way down to the bottom. Any ideas if it can be fixed or should I make a trip to tractor salvage yard find a other? _________________ 1940 Ford 9N
1952 Ford 8N
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC
1946 Case VAC |
| Back to top |
Posted: Tue Feb 02, 2010 7:52 am Post subject: |
If the crack is just on the top deck I would not worry about it, I have one VAC that was cracked top of the deck through the center main bearing, and it would pump oil into the cooling system. Make sure you get a block number VT328, as the older ones are slightly different. _________________ Jim
| Back to top |
Peterbilt Member
Posted: Wed Feb 17, 2010 9:05 pm Post subject: |
Update: Im still looking for a block. Seems like all the tractor salvage yards around here cashed in when price of scrap was high. I had a few peaple tell me to use a 2 or 3 part sealer on it, but I plan to work(playing in the dirt) the tractor. The cracks go all the way down. By next week Im going to pop the pistons and sleeves out to get a better look. Everything else on the tractor is going good . _________________ 1940 Ford 9N
1952 Ford 8N
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC
1946 Case VAC |
| Back to top |
Posted: Wed Feb 17, 2010 11:24 pm Post subject: |
I have farm tractors that I farm with that have the blocks cracked on top, does not mean anything in a gas engine head gasket will seal it. I would pull the sleeves and see if it's cracked on the bottom. _________________ Jim
| Back to top |
Jhaydeno Member
Joined: May 12 2008 User's Age: (40) Posts: 104 Location: Dover, PA member # 1087
Posted: Thu Feb 18, 2010 1:38 pm Post subject: |
If you are still looking for a block call Clair Myers Case on Lake Road in Thomasville, PA - 717 259 0453 - Really old guy has tons of 40's & 50's Case parts in the junk yard. _________________ I enjoy fixing anything with wheels! |
| Back to top |
Peterbilt Member
Posted: Fri Feb 19, 2010 1:54 am Post subject: |
Sweet, Thanks _________________ 1940 Ford 9N
1952 Ford 8N
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC
1946 Case VAC |
| Back to top |
Peterbilt Member
Posted: Thu Feb 25, 2010 2:44 am Post subject: |
This is were Im at so far.
Does anyone know were I can get one of these seals? Half of the rubber in it was missing and leak like crazy. I know the picture is not the best. Its the seal for the lever that activates the PTO.
1952 Ford 8N
1949 Case VAC
1949 Case DC-4
1939 John Deere B
Sold
1939 Ford 9N
1939 Farmall H
1944 Case VAC
1946 Case VAC |
| Back to top |
Posted: Thu Feb 25, 2010 5:48 am Post subject: |
The last one I rebuilt had an actual oil seal in it, may have National numbers if needed. Nice progress. _________________ Jim
| Back to top |
