| Author |
Message |
jdcrawler Member 250 club
Joined: Mar 01 2008 User's Age: N/A Posts: 415 Location: northern Michigan member # 912
Posted: Sat Jul 10, 2010 11:28 pm Post subject: Building my tractor ( darn production setbacks ) |
In my last post I had the tractor running and drove it out of the garage for the first time.
This test run showed up some problems that needed to be addressed.
#1 ..
The transmission was making a nasty noise when I let the clutch out to drive it.
It did this in all of the gears but not when it was in neutral.
Turns out the rear bearing was shot. I replaced the rear bearing so that should take care of that problem.
The other bearings seam to be OK.
#2 ..
When I last had this engine running ( a long time ago ), I seam to remember that it ran OK and didn't smoke.
It did however, leak oil real bad and the engine was caked with it.
In talking with my son, we decided that it probably sat in a hot warehouse a lot and the seals got cooked.
Part of that conclusion was because the other rubber parts on the cart were all dry rotted and cracked.
I pulled the heads off and inspected the cylinders.
They both looked really good and I could not feel any ring groove edge at the top of the cylinders.
So, with the cost of overhauling an Onan engine being as hi as it is, I decided to take a chance that the rings were still good.
I put new gaskets and seals in and put it back together.
As before, the engine ran good and did not smoke and now it doesn't leak oil.
However, when I checked the vent tube, it was puffing air out like a compressor.
When I revved the engine up, it spit oil out the vent tube.
I pulled the engine back down and pulled the pistons out.
The top ring on both pistons was broken in half so I'm going to have to spend some money and rebuild after all.
#3 ..
The last time I was held up on this project was because I was looking for a governor for the engine.
The governor on the Onan engine is on the end of the camshaft.
A member here was kind enough to fix me up with another cam with the governor on it.
It turned out that his cam would not work in my engine.
I wasn't able to come up with the correct cam so I went ahead and used my old cam and hooked the throttle cable directly to the carburetor.
My son tells me that it really would work better with a governor and I have to agree with him.
In just the short time it took to drive the tractor out of the garage, around the yard a little and back into the garage, I was fiddling with the throttle lever a lot.
So .. I'm back to trying to find a cam with a governor on it.
I also need a different carb as this one won't work easily with the governor setup on the engine.
This carb is off a B&S V-Twin and has the levers on the wrong side.
The last time I was looking for parts, I spent the time fixing my truck.
This time I'm working back on a Bolens Ridemaster for my Sweetie. _________________ Ray
1945 John Deere Lindeman crawler ( modified )
1949 Agricat crawler
1948 Bolens Ridemaster
1953 Bolens Ridemaster
1959 Chevy 1-Ton truck |
| Back to top |
JJ. in B.C. Active Special Moderator
Joined: Feb 22 2007 User's Age: (69) Posts: 5124 Location: Miracle Valley, B.C. Canada. member # 49
Posted: Sun Jul 11, 2010 2:05 am Post subject: |
Sorry to hear of the setbacks Ray, i bet Harry Ferguson had those
kind of days
We will just have to wait along with you for the remainder of this build, _________________ JJ. |
| Back to top |
jd2840 Active Moderator
Joined: Oct 10 2009 User's Age: (13) Posts: 1873 Location: Temple,Texas
Posted: Sun Jul 11, 2010 4:19 am Post subject: |
i would bet cash money that you can get it figured out  _________________ -Ray-
My collection counting both grandpa's
1937 Farmall F-20
1939 Allis Chalmers B
1941 Farmall H
1944 Farmall M
1949 Farmall H
1954 Farmall Super M-TA
1955 4400 Chevy Truck
M-H no. 8
IHC no.9
2 John Deere 120bs
IH Model MF grain drill
Old Wagon
IH 1 Row Planter (converted for tractor)
25ft Long 8ft Wide Trailer (Brand Unknown) |
| Back to top |
Posted: Sun Jul 11, 2010 11:49 am Post subject: |
...... GOOD NEWS ......
Just won a camshaft and carburetor off ebay this morning so the tractor will be back up and running shortly after the parts arrive.
Hopefully this will be the right cam this time. It looks like it is from the photos on ebay but I won't know for sure until it gets here.
This is just another one of those "learn as you go" things. _________________ Ray
| Back to top |
Posted: Mon Jul 12, 2010 8:06 pm Post subject: |
The rings and rod bearings came today.
Both cylinders are all honed and the new rings and bearings are installed.
I'm not going to take the rest of the engine apart until the cam gets here and I can make sure it is the right one that I need.
If so, then the flywheel, front cover, lifter cover plates ,fuel pump and points box all come off ( again ).
Then I can remove the valves and lifters, put in the new cam an start putting it all back together again ( again ). _________________ Ray
| Back to top |
Posted: Mon Jul 12, 2010 11:44 pm Post subject: |
You are going to be very familiar with the innards of this engine
before you are done Ray  _________________ JJ. |
| Back to top |
kiwi071 Active Moderator
Joined: Dec 25 2007 User's Age: (71) Posts: 10083 Location: Christchurch, New Zealand member # 679
Posted: Tue Jul 13, 2010 8:14 am Post subject: |
You must be a very patient spanner man Ray,you will have it running in no
time  _________________ kiwicolin |
| Back to top |
