How do you check oil on 1937 Case CC Tractor correctly ??
Is it the motor or diff? if its the diff there is an oil level plug on the side of the diff.How do you check oil on 1937 Case CC Tractor correctly ??
Heat and pull is about all you can do.Hi there , I don’t have an answer to your question but I have another for you , I’ve a 1939 case Cc and I’m trying to get the drive wheel off the side of it . Any idea how it’s done? Thanks
