Hi there I’m restoring a 1939 case Cc tractor. I’m have trouble removing the break wheel on the side and the water pump at the front. I’ve tried penetrating oil , heat and pullers but nothing is budging. Is there a certain procedure to doing it ?
thanks Andrew
21650
21651
21652
21653
Just what you are doing, heat and pull. (Sometimes the pulley on the front of the motor is threaded which needs undoing, look closely at the shaft to see if it is threaded.)
Thanks for the reply , I got hold of the service manual too so I will try it at the weekend !!
Good luck
