Hello everybody, just got my great grandpa's 1947 Model A home a couple of days ago and wanted to have a place to ask questions and post progress on my restoration! So in my introduction post I posted that this tractor hasn't been run since the 1980's, well come to find out the last time it actually ran was around 1974, so this thing hasn't ran in about 45 years, which explains why a lot of the things on this tractor are stuck. After getting it home, I immediately filled both the cylinders with a 50/50 acetone - ATF mix and let it sit. The next day I pulled the shroud off the flywheel in order to turn the flywheel more easily, and believe it or not the engine turned over! After removing the spark plugs I got it turning really good (resulting in my arm getting covered in my ATF/acetone mix). So as far as the engine is concerned, the Southern California climate spared it. The brakes on the other hand weren't so lucky. Both are near the point of being rock solid and made loading the tractor a real pain. I removed both of the bolts securing the brake assemblies on, and nothing. They are stuck on there real good, I got both of the assemblies to rotate about an inch, but other than that they are not budging off the tractor. I was wondering what methods you all use for pulling these assemblies off when they are stuck like this? I jacked the back up to where I could rotate the wheels, and every time I rotate the wheels (what little bit they move anyways) it causes the brake assembly to bounce up and down slightly, however even after doing that a bit it didn't seem to help loosen it at all. That is about all the progress I have made so far, soon me and my dad are going to be pouring a concrete slab for this to sit on that way I have a proper place to work on it! Here are a couple of photos of the tractor
