1 - 20 of 23 Posts
I'm hoping to bring my 1951 VAC along as I fix up the '49. It was parked with clutch issues about 12 years ago. It has an Eagle Hitch. I've removed some sheet metal, am rebuilding the carb, today I stripped the gas tank. My plan is to put the tank/carb/sediment bowl back on, change the cap and wires, and see if it will fire up. I've looked into the cylinders, and turned it over with a jump box, the engine is free.
I just scraped off some gunk, then went at it with a wire brush on an angle grinder. :D Took about 1 1/4 hrs. The original paint on that tank was pretty thin.
Looks like that'll be a fun one to work on. It'll keep ya busy for a day or two. Hope she fires over for ya without much trouble.
Painted the gas tank, baked enamel, lol. Not to worry, it will be back in the shop before Mrs. CTPhil gets home. ;)
Thanks. Mrs. CTPhil was not amused however.
Got out the chainsaw and cut the saplings and vines growing through it and dragged it free. After a dozen years the front tires are flat, but the rears are still inflated.
You bet!
Discussion Starter · #13 ·
Yes it is.
Discussion Starter · #15 ·
1031d said:
Is that a CASE sickle mower on the back?
Yes, I believe it is a model 41.
Discussion Starter · #17 ·
I am actually tempted to sell it. I've replaced enough pitmans to become a real fan of the pitmanless sickle bar. ;)
Discussion Starter · #18 ·
I put on the rebuilt carburetor, put in the repainted tank, new cap and wires, but no go. No spark to to the plugs. So i ordered a tune up kit and put it in and it fired up, first time in a dozen years. :) Video here: http://youtu.be/np0NUeRQvQk
The smoke is paint burning off a new muffler.
The hydraulics work too, I pulled the rockshaft control and the lift arms shot up with no hesitation.
Great looking project :)
1 - 20 of 23 Posts
