I have a new alternator,new 12v coil, alt bracket, 12volt battery. what do I need to do with the starter that has the start switch on it? The 6 volt system was positive to ground. Can anyone help me Thanks
Frank
Above link will help you. Your 12v battery will be negative ground, and your 6v starter will work fine, no changes to it needed. Welcome to ATF.
