1970 Farmall 140 lights question
Here are the front light assemblies.
How to remove the plastic plugs ? Twist left and remove?
I have twisted but stopped short of maybe breaking them off.
There is the rear sealed light with a smaller bulb.
There are the 2 front sealed light bulbs.
I see plently of new ones for sale.
But for now, where to find sealed light bulbs like these ?
Discussion Starter · #2 ·
I sprayed the plastic plugs with pb blaster last night. I used pliers to pull them straight out tonight.
one of 3 bulbs will light up with alligator clips to the battery. It never lit up from the switch.
the wiring has frayed insulation. I will try to reuse the plugs with new wiring.
I do see sealed bulbs online
Seems like you have figured it out. The sealed beams should be available at a good parts store even if they have to order them. Online is probably best. Steiners probably has them.
