Is it possible to adapt a 3 point hitch onto a 1950 Farmall C? I now have a sickle bar mower on the tractor but my field is rough and I'm not sure it's going to be possible to use as the field is now.
Reactions: Mcrafty1
YES! There are many adaptations agree with Jim about Steiner great but check the web for possible used. Not a complicated set up. Don't recommend for plowing though since no Draft capability.
Thanks I will. As of now I'm going to wait to try the sickle bar before I go in another direction, the guy that's been doing my field with a rotary mower said he believes the sickle bar will work, if so I won't be needing a 3 point hitch, the field mowing is all I intend to do with the tractor at this point. Also I have the option of using a rotary with the two wheel setup on the rear that doesn't need to be raised if it comes to getting a rotary mower. As it turns out I have a neighbor that has a C with one of those types of rotary mowers and it works fine.
