cannot shift gears without shutting off motor when clutch is depressed the tractor stops but will not shift gears Know for sure throwout bearing is badly worn and clutch probably shot also
It wants a new clutch disc and clutch thrust bearing, the fingers will need looking at as well that's why you can't shift gears.
Have you tried adjusting the clutch pedal underneath the floorboard?
Discussion Starter #4
thanks I'll have to bite the bullet and break apart and replace all needed parts
Discussion Starter #5
Thanks Jim, yea I adjusted by the manual that I have and if I go too far in or out either too loose or terrible noise from bearing I'll have to do shop repair
