Hello all,
My cousins and I restored a 1951 B (pic attached). It has been converted to 12 volt, negative ground, with alternator. I have thoroughly cleaned the carb, replacing seals and gaskets, etc., along with replacing fuel filter. I have set the idle adjustment to 2 1/2 turns, and the load adjustment to 3/4 turn.
My problem is it doesn't want to "throttle-up", without gently increasing the throttle a little at a time. When I increase the throttle quickly, it "chokes down" and dies, unless I pull the throttle back to idle very quickly.
I'm sure that I'm not setting something correctly or am forgetting something, and think it should be a relatively simple fix.
Does anyone have a solution or suggestions for correcting this problem? I appreciate any help that y'all can provide.
