I stole a little time to work on the little ford, The original plan was to get it running and the tires holding air so I can move it around and restore the VAC first. well the #1 exhaust valve was stuck open so I went ahead and pulled the head off. I did not have it in a convenient spot for long term storage so I had to turn it around and move it. I got the motor out and invertedt. The sleeves and bottom end look ok. I got the valve out without bending it, everything else looks ok. I plan to hand lap the valves and plastigauge the main and rod bearings, rebuild the oil pump and put new gaskets and seals in it.
I'll try to get the pics up later.
