Strange problem Was moving a couple things around and for no reason just shut off. Resarted right back up and after a couple minutes shut off again. Started right up again. Put it away and just let it run and after a while went to shut off pulled the choke and she kept running. When it shuts down it will fire right back up.
Have no miss but like it has a mind of its own.Not sure where to start. Gas is same as has been in it. Not had any problem till today. Gas is about 1month old.It is like you shut the switch off but when ya choke it it keeps running.Any ideas where I should start looking? Thanks.
Amp meter is maitaining betweem 2-9 amps.
