I need some help figuring out my problem(s) with my '48 8n. When I parked before the winter it ran great, as normal. Went to fire it up a few months back, and it wouldn't start. I started with the cheap stuff that it was due for anyway, points, condenser, cap, and rotor. I have the front mount distributor, so I pulled the whole unit out to rebuild. Put it all back together, still no spark at the plugs. I knew my coil was weak, as the summer before when it heated up I lost spark, so a bought a new one. I was in business now, got good spark and am running. But the tractor runs like garbage at high rpms. I know I know, check the firing order. Checked it 10 times 1243. So I though maybe I have a fouled plug, so I buy new plugs and copper core wires and reinstall them in the proper order of 1243. Still runs fine at an idle, but not good at all at high rpms. I've added heet to the tank to get the water removed(not sure if there even was any). On the advice of others I put some Marvel Mystery Oil in the cylinders and gas on the though that maybe I have a stuck valve, still nothing. As soon as I can I am going to check my compression. I have even cleaned the carb and put a new sediment bowl on the darn thing. I feel like I'm going crazy, nothing I or anything anybody has suggested has worked. Any help would be great.
Tom
Tom
