Here are a couple pictures of a Allis G that was narrowed up.
rebuilt the motor completely,rebuilt axle,new seals and rear brakes.
Also a WD high crop thompson with the Round spoke fronts also found new 21" tires are to follow.
Very nice restorations. You have an eye for unique tractors.
Good luck with both little G's. Keep us posted on the progress.
Would enjoy following your work through the "extra high" little G.
Also today i had bought a WD 45 diesel about 1 year ago did not want to run they have shaft that twist off in the head of the injection pump.
I had another injection pump off a oliver here so we did some checking and change out the head portion nice to hear the tractor run.
runs out good.
here are a couple pictures also in the rear is a spray rig that was used down in LA.
Has UC high crop front and rear wheels D 17 power unit and from the torque tube back is D 15Diesel with the axle extensions.
