I have a CASE 611B-L with a leaky power steering cylinder, I have the CASE rebuild kit and manuals but the manual does not show how to get the cylinder apart, I have the retaining clip out and the cylinder removed from the valve but the rod will not come out. Without getting the rod out how do I replace the seal kit?
Pictures as requested:
Factory Service Manual
Here it tells me the cylinder can not be disassembled, then how do you get the new cylinder kit installed?
-Willy-
Pictures will help us know what you are working on. If we cant help you here, try contacting a hydraulic rebuild shop. They may have even worked on similar cylinders in the past.
Best help I can give you.
-Willy-
It should be mentioned. A poor man often doesnt replace items with OEM parts. Sometimes it is easier to replace hydraulic cylinders with "welded" cylinders. If you have a welded cylinder, these were never meant to be serviced. As I posted above, pictures will help alot in determining how to best help you with your quandary.
Just from what I see in your pictures, you have a factory welded cylinder. I ran into this on a Ford 3000 recently. It now has after market, serviceable cylinders, and they were a heck of a lot less expensive than Fords.
Discussion Starter #5
I couldn't edit the post a second time:
I used a $1.99 pick set from Harbor Fright to pull the dust seal out, that a 20 minutes of work. Once the seal was out the spacer dropped out when I turned the cylinder upside down and worked it. Last was the o-ring, again with the pick set I hooked it and pulled it out in about 10 seconds of work. With TLC and STP everything was assembled the snap ring being the hardest item until I realized my snap ring tool could be converted to an 'innie' tool (squeeze the grip the nose goes in).
The worst leak was the spool assemblage ball stud end, it was pouring oil out and the new spool kit stopped that.
