6wheeler
Hi all. I thought I had IH plow spoken for . But, when I picked it up? I learned it is a Case Centennial 2-14" plow. I have a problem. The wheels are pretty rusted out. They are spoke on rubber. I was wondering if any one may know if I can change them over to bolt type hubs. And, If so? Where could I find the hubs. Finding out this plow doesn't have 1 single bearing on it was a surprise. The wheels just slide onto the spindle with shims and a pin to hold it. Weird. Thanks Pat
If you want to go to bolt on wheels and tyres, you will have to get the existing hubs turned to allow a plate to be welded on with the wheel nut configuration on it. Any competent engineer should be able to do it.
