I posted this on the old sight but with some new members I thought I would again Wonder If any body has ever used these and have any tips on setting up. These are for the eagle hitch.
Set up is basically the same as a mouldboard plow. Set depth and level the plow side to side and front to back. I like to run the tractor up on a block (both the right front and right rear tire) the same height as the depth I plow and level the plow to that. Raise the tail wheel the same. Then make fine adjustments in the field....James
Thank you both for the help and Nick that section of the owners manual is going to be invaluable Thanks so much for taking the time to post. I'm going to get my son to download on the computer when he gets home don't want to lose that.
Gordon
