Guest
·I have a Stihl MS 390. The chain oiler has quit working. Is there something simple to look for??? The bar is clean.
Looked in the tank and pulled the end of the tube up and it looks clear. It will oil good for about 4-5 minutes then quit???Stephenscity said:Mine did that one time and the tube was just sludged up.
That might. I like to run ATF in the engines a lil before an oil change.bertman said:Wonder if you ran some atf through it once in a while it would clean it? Its high in detergents :?: :?:
Souuds like a good idea never thought of that one.petra79 said:That might. I like to run ATF in the engines a lil before an oil change.bertman said:Wonder if you ran some atf through it once in a while it would clean it? Its high in detergents :?: :?:
