Hi, I have a 420 John Deere. I want to change it over to a 12 volt system. Does anyone have a diagram that I can follow to change it.? Do I have to change the starter over to 12 volt also.? Where would I get the starter.? thank you very much.
You do not need to change the starter. If I had changed my 40S I could send you a diagram. I have changed an Allis C and several Farmalls. I'm not sure they would be the same as a 420. I made my own alternator mounting bracket. You need to use a ballast resistor to use your present 6 volt coil. You will no longer need a voltage regulator. Change your light bulbs to 12v bulbs. Steiner tractor probably has what you need for your job.
Reactions: RacerX
James thanks for posting this info. I have the 40S that belonged to my Grandaddy. I have left it with a 6v system for years simply because it worked fine. I am ready to change to 12v though because I know I will use it more. The price and availability of 6v batteries is a large part of my decision.
Nope. Put the alternator on, change to negative ground, reverse the connections on your amp meter. My Farmalls are mostly done like my Allis C.
Reactions: oliverguy
CASE VAC14 Can the original GENERATOR be rewired to produce 12 volts.. Right now it is all changed to 12 volts with an alternator - would like the original "Look" with 12 violt system. How do you do it, or better yet where could you get it done.
