I installed a new clutch,pressure plate and bearing 2 times and I get the same results. I cannot get into gear while running. I have about 1 inch freeplay in the pedal and it appears to disengage the pressure plate. My tractor is a 1953 farmall super c When running it just wants to grind the gears when trying to put into any gear. Help Please Is it possable that I did not tap in the bearing shaft far enough?
