HI all i was pulling the engine out of my massey harris 81. guess what the engine is cracked . i never seen a wet spot. the engine seems to run good. has anyone fixed a cracked block. beings how its not leaking should i leave it alone. its not going to plow field. just a hobbie tractor. thanks willie
i have a ford 951 with a crack that runs between freeze plugs. has new plugs now and has never leaked. if it started to leakl i'd braze it or silver solder it.
If it ain't broke, don't fix it. Dads old IH truck had a crack from one end of the block to the other and it was pushed out the thickness of a dime. Never leaked a drop. Ran it like that until it was so worn out it just quit.
HI thats what i was thinking. some where down the line this tractor was painted orange. yuk .i would like to give her a red paint job. and put it in the front yard for all the john deer people to see. didnt anyone use anti freeze back then.
During WWII, When dad couldn't get alcohol, he used coal oil in tractor & car radiators as both had bad leaks & weren't used/driven (no thermostats either) very much in winter months. Permanent antifreeze was a big cost item then.
I had a cracked block on my '49 VAC, it was slowly leaking coolant. I cleaned it up and put PC-7 (JB Weld?) on it. That was over 20 years ago.
If it's not leaking then it probably only needs paint.
