Did a bit of work on the tractor today, the lever is curved with a threaded top for a knob. Took the distributor off, cleaned the points and reinstalled. Still won't fire but I only had 4.2 volts at the coil. I will put a jumper directly from the battery the next time to see if I can get it going and then deal with the switch and undersized wire going to the coil. The owner is quite willing to spend money so I will get him to bring up plugs, wires, switch and points. He already knew that he had to replace the fluids and both front tires to get it runable and then I suggested he use it for a while to loosen up everything else before he does any more mechanical work. This tractor also has a belt adapter on the pto that will have to come off and put in storage. Have not seen one of these before but I suppose they would mostly be kept out of sight in storage.
