I ordered the seal to replace on my Farmall Super A on the rear left wheel, the seal that is for the seed drill with the teeth sprocket. I removed the retaining pin which goes through the sprocket but can't remove the sprocket? How do I remove the sprocket to get the seal retainer off to replace the seal?
Undo the 4 bolts that hold the casting, then everything should come off.
