1 - 1 of 1 Posts
Discussion Starter · #1 · (Edited)
I’m working on a Ford 3000 that my dad bought new 1972.
my 3 pt only works while engaging one of the asc remotes .I see 2200 psi at pump test/bleed port only while a remote handle is in lift position. ( 2 spool asc no detent )
this after total pump and top lid rebuild. suction filter removed and cleaned. Discharge filter new. all orings replaced. I’ve gone through the pump and top lid twice to double check my work.
my 3pt initially worked but wondered up and down when connected to a bush hog etc. I replaced cam follower pin at lift cylinder,it was badly worn.
suggestions or ideas would be very much appreciated.
1 - 1 of 1 Posts
