Have a 1957 960 that was originally propane switched to gas. No gauges in dash. Put in ammeter and engine temperature gauges, but cannot find a port, plug or any logical opening for oil pressure sending unit. Manuals, online or parts suppliers are no help.
I would research where they put the line in on the gasoline models.
You may have to drill and tap you a hole.
Finally did find it buried behind the transmission/gear oil pump with a 90 degree fitting. Tight space. Original was 1/16" fitting hole, replacement is 1/8" fitting with pinhole copper line. Had to change 90 fitting , it fit and new gauge is in place.Trouble with manuals and blown-up parts diagrams is that they are not very detailed and the replacement parts pics only name parts that are available.
