I have been lurking here for quite some time while restoring my prize a Farmall BN. I have a problem which I am sure you guys can help me with. During the inspection phase, it was apparent that the left rear axle seal has been leaking for a long time. I have removed the rim, wheel weight, and inner disc or whatever you call it. I also removed the cover plate on the inside and the large bolt on the axle shaft inside. On the outer part I removed the 4 bolts that appear to retain the axle. How much force is needed to slide the axle out or have I forgoten something? The shaft won't budge. Help.
Thanks,
