Anyone know what this plate is and what goes in this hole? Just started leaking fluid . Almost directly under shifter area ?
Anyone know what this plate is and what goes in this hole? Just started leaking fluid . Almost directly under shifter area ? View attachment 23109
If it's what I think it is a cotter key goes in that hole. That looks like the clutch inspection plate. There is a hole so that when the front transmission or rear engine seal starts leaking the clutch compartment doesn't fill with oil. Should be a cotter key through the hole to help keep bugs and things out.
What do I need to do to remedy the leaking and solve the issue ? I'm new to tractors but also mechanically inclined thanks in advanceIf it's what I think it is a cotter key goes in that hole. That looks like the clutch inspection plate. There is a hole so that when the front transmission or rear engine seal starts leaking the clutch compartment doesn't fill with oil. Should be a cotter key through the hole to help keep bugs and things out.
Thanks for your help.Most old tractors mark their territory to some extent. If it's not bad enough that it interferes with working the tractor you may want to just use a drip pan to catch what drips out. You can remove the inspection plate and see where the oil is coming from. You'll need to split the tractor to replace the seal that's leaking. Operator and repair manuals are still available for most old tractors and have what information one needs to maintain them. All States Ag is a good place for new and used parts.
have you fixed your problem?Anyone know what this plate is and what goes in this hole? Just started leaking fluid . Almost directly under shifter area ? View attachment 23109
