I think it a 801 series with the strange shifter live pto, but my block has a hole a big one and busted rod, neighbors disconnect the rod and patch and spider weld the hole he 80, it start fine but make noise after 20 min, cry with a bush hog, block is expense to find and buy I found a old 713 bachhoe ford I can get cheap at the savage yard is the the same block and engine will it fit in the 801 series thanks
713 is the model of the backhoe attachment. They were built from 1959 until 62 and mounted on various model tractors.
Look at the tractor number stamped on the flat spot above the starter. Should be three lines of numbers. That's how you will know if it will fit.
