1 - 1 of 1 Posts
Needing to replace a hydraulic line that is leaking. Need to remove flare nut from pump. Helpful hints...Use a big flare wrench to remove??? Box end??? Appears as though nut is made out of a softer metal and I do not want to damage it. How tight are these typically? Can't apply heat (or do not want to) give its proximity to the gas tank. Thanks for any helpful hints.
1 - 1 of 1 Posts
