Ok, so I got this 36 JD b, new points and a carb clean and its running, tried pull starting it before the new points and the clutch seemed operational.
Now that it's running: the clutch wouldn't disengage so I could put it in gear, pulling the clutch lever and applying brake to the pulley slowed the engine, I couldn't pull it hard enough to stop the engine, but also couldn't put it in gear.
Ive disassembled the clutch and it seems like it should be operational, but even with no clutch disc in it at all; rolling the tractor turns the engine....what am I missing?
Thanks in advance...
Discussion Starter #2
I may have it figured out, the part number on the clutch disc is B1304R, which is for a 39-40 B...someone seems to have installed the wrong clutch disc, mine(1936) should be a B159R, from what I've found...
