1 - 1 of 1 Posts
JD301A
There is always a little chattering from the steering when the tractor is first fired up and occasionally while it's running. I have been bleeding the air off the fittings on top of the rear axel. I'm not sure if that is removing all the air. I've got a manual for the tractor that indicates a point under the pump but that fitting is not physically there.
The clutch also gets weak, especially with PTO, after a few hours of good working. Running a 6 foot tiller so makes it a little rough on the gears. Not sure if this is related or something with the pump.
Any suggestions of how to address these problems is greatly appreciated.
Alex
1 - 1 of 1 Posts
