1 - 12 of 12 Posts
reposting theis at the request of aother member.
not.. this is a light duty lift meant for a couple hundred pounds.
currently the rockshaft is 3/4" and is doing fine. I have since located a 1" rod, and if the rockshaft does bend, will swap it out for that.. etc.
I originally mocked it up using scrap rebar to get my angles and distances correct.. then went back and used better metal stock and clevis ends, etc.
unit is working well for it's intended purpos.. I've pulled a spring tooth harrow with it as well as a pasture drag harrow many times.. working great. I wouldn't try to lift a 400# 4' mower with it till I swap to a 1" rocksahft though.
lower draft links are ford from an N.. etc..
Nice mod, I don't suppose you have ever done the same for a Cockshutt 30?
forgo the initial pic of the clevis setup at the hyds.
this was the '2nd generation' hookup I used. mockup was nothing mor ethan a 3/16" thick washer welded head on to a piec eof rebar.
this one was a clevis end with female threads.
I took a section of round stock and threaded the end and screwed in flush to the clevis, then welded the face and lower edge up. then 'coaxed' the round stock into the sqaure tube. made about a 6" overlap. had drilled cross holes int he square tube to weld thru so there are 4 weld points on each face of the square tube wher ethe round stock went in, plus the weld around the joint. this is right after weldignthe first one. i went back and since, cleane dit up and hit another pass and reground it smooth. looks pretty decent.. and don't forsee it coming out anytime soon without help from a torch or chopsaw.. :)
Looks good and I'm sure will come in handy, Maybe not for a 7'brushog but for the light stuff it's nice to have a 3pt option. I cheated and didn't have to do any figuring or welding I bought a used fasthitch 1pt to 3point conversion for my cub loboy. Only for the light stuff. The cub can't lift or pull a lot but I figure it will be good for the 3pt rake.
Kirk
1 - 12 of 12 Posts
