Bad axle bearing letting the bull gear drop down?
....James
....James
I don't think it is. Cause it would make some kind of noise while pulling it home. The field was like a mile from the house. So wasn't too far to pull it with a chain.jwal10 said:Bad axle bearing letting the bull gear drop down?
....James
I tried almost all the gears and it did it. Hope its a simple fix, where I don't really have to tear it down.John M said:Just guessing here, but the first thing that pops in my head is the rubber washers in the clutch connection above the belly pump, then Id have to say a bearing in the constanst mesh assembly or the lower bearing on the bottom shaft. These would make noise when under load, and not when its not under load, and make the clutch pedal shake. Does it do this in all gears or one specific gear?
Yes it shakes. And you hear a popping noise while it does it.wizzard said:if the pedal shakes then it has to be clutch or imput shaft related
