What do I need to hook a Ford manual transmission with 4 forward gears and 1 reverse gear up to a Ford industrial tractor that has a select-o-speed automation transmission. And vice versa hook up a select-o-speed to a Ford that formerly had a manual transmission.
You need to swap everything from the flywheel back, the gear ratio's in the diff are different requiring they be swapped as well.
Basically you'll be swapping the engines, front axles and steering from one tractor to another.
What models are you working with.
