1 - 8 of 8 Posts
I recently bought a VERY complete Pony. I have only found one piece missing and I can't find a picture/name or supplier anywhere. The hood is held in place using what I would describe as a piece of 3/4" wide maybe 3/16 flatstock in the shape I would call an elongated flat bottom "S". The hook is on a loose bolt, put a little down pressure on it and it grabs the top of the hook and stays put. I have one on one side and will try to copy it but would rather have original. I can't even find mention of it or know what to call it. I've searched latch, hook hold down, tension etc etc. In looking at photos many Ponys have a bolt and washer in its place but I would love to find the original hook, I think it is slick. Any help pointing me to it or if you have one to sell would be appreciated.
Ron
Maybe you could post a picture of it. I dont remember seeing anything like that on any ponys I have owned or looked at. Hood has always just been bolted on. Welcome to the forum
Hi RJ
It took my a little while to figure out how to load these. I hope I do it right
21608
21609
21610
the last picture shows it hooked. Apply a little pressure on the hood and press it in, it unhooks. (middle picture) the other picture is the piece out of the tractor. The bolt and ny-lok give it enough travel to hook. Now that I have this one out I am pretty sure I can make it but would still like to know if it is available.
BTW this is my first post, sorry if it is too long.
Yes, your post is fine. I can see the photos good.
I Think you will probably have to make that piece tho.
I have never saw one with a hood that latched like that.
Thanks for the pictures
Discussion Starter #5
Yes, I made it last night, not identical but real close, once installed it won't be seen. Thanks,
Or they will forget the details as they walk from one side of the tractor to the other. Maybe I'm just ttalking aboiut myself.
Discussion Starter #7
Way too small a difference to notice. A bolt in a slot however would have been easy to spot. Both sides look identical with the hood on. Thanks,
With these old tractors we often have to be creative. Glad you got 'er done!
1 - 8 of 8 Posts
