Ever since putting my MH50 back together i have noticed that it sputters some when ever the engine RPM is sped up. It also seems that when i start it it will only run on 2 or 3 cylinders for a few seconds untill it gets going a little bit then it evens out on all 4. Do you think this is a carb issue or possibly a timing issue or maybe even something else altogether.
Thanks so much
Matt
thanks, I will play with the carb adjustments some. I dont think it is a gas flow problem because I had the tank off and I cleaned it, along with the sediment bowl and the fuel line.
Thanks fot the help.
Matt
