1 - 11 of 11 Posts
I cannot find a picture of a model R with the hydraulic cylinder, with hoses, hanging from the support bracket on the tractor footplate. Was this a safe attachment when travelling, or could they jump off the bracket?
I also need the bracket AR1567r if anyone has one.
Russ
OK So that request has failed! Any ideas folks?
Anyone got a photo of the quick release hose set up? I understand if the plow hit a rock, the hitch disconnects and the cylinder hoses detach?
I also have a long rod fitted on the tractor for disconnecting the clutch on the hitch breaking. I think there is a bracket between the clutch level operating rod and the disconnecting rod? Can anyone assist?
Russ
Hi,
Here some picture of mine ... ;)
Best regards from Luxembourg,
Tom
Reactions: John P
Many thanks Tom! I will aim for this set up. I think there should be break away couplings on long tubes?
I also see you have the correct draw bar - another item on the wish list!
Russ
Yes I emailed and sent pictures from the parts manual but no reply, even though I have reminded them twice.
Russ
1 - 11 of 11 Posts
