Folks, I was mowing the grass the other day with our craftsman tractor with belly mower. I bent over to pull a weed out. This tractor has the safety switch in the seat so the engine started to die. I sat back up before it died and it was up and running again, but the mower stopped working. I shut the tractor off and pushed the mower PTO switch to the off position and started it back up. I pulled the PTO switch and the mower still won't run.I've checked all the wiring connections and they look OK. Do you folks think the PTO switch is bad or the actual PTO clutch? All I get is is a faint click when I pull the PTO switch on.I've done the bend over thing while mowing many times and this has never happened.
