Working pressure of the injectors is 175 atm. Yesterday I told Pepe to check the injectors because he has a funny machine to fix the working pressure. He called me today and told me that three injectors were stuck. I drove to his workshop, and they were completely stuck. I grabbed the thin stab with a vise and slowly pried the outer shroud. It worked. The injectors were just glued with solid fuel remnants. Otherwise they were in first class condition. Once cleaned they performed as new.
This week I have to look for some new pistons and rings in the net. I have measured the sleeve bore. It´s 92 mm, that makes 3 5/8”. I thought all Cropmasters Diesel had 3,5” bore. Anyway, it´s great news, because it seems 3,5 pistons are no longer available. 3 5/8 pistons are easy to find.
