And this is a problem I would like to solve. When I dismantled the Cropmaster I realized that the radiator had no shroud behind it. It is true that some early tractors never had it but I always had some thoughts about it. Then, I remembered that the Tractor museum had a Cropmaster 25D in the collection. So there I went, I opened the side panel and there it was...
It had a shroud.
As you can see it also had the original two blade fan. Mine has a four blade fan. I think that the previous owner had tried to improve the cooling changing the fan, and then it did not fit the shroud and away it went. Trying to find a solution I went marauding the museum´s junkyard and there I found a Nuffield radiator with the shroud still attached. It was in very good shape. Permission was granted to pick it. I did not take the radiator altogether because the Cropmaster radiator has a weird tank on it. It remains to be seen whether the shroud will fit the radiator frame and the fan.
In the meantime I was able to find an original shroud in a british junkyard, but I am very reluctant to order it because after Brexit any order from Britain is intercepted, incredibly delayed and heavily taxed. Ask me how I know. It is sad but, with the current final prices of british spares, this Cropmaster might well be the last british tractor I restore.
It had a shroud.
