121 - 140 of 157 Posts
Discussion Starter · #123 ·
All the wiring related to the dash has been labelled, installed and fixed before placing it on the tank. The choke cable is also ready. Now I have to go through my own pics and the manuals to find how the cables were tied.
I have attached this strip of fiber cloth to the tank. It is there to avoid scratching the tank with the cowling. I used the belt of a blind that can be found in any hardware store. The original was made of cotton, but cotton traps moisture, and moisture means rust, so I upgraded the strip to a modern fiber one. I dipped both ends in superglue to avoid fraying. The color shoud be a bit paler but it is good enough for me.
21786
Discussion Starter · #124 ·
Today I started filling the cooling system with antifreeze coolant. Then the water pump started to leak badly...
I felt truly demoralized when I saw those drops falling happily.
I really should have checked the pump and the whole cooling system and not only the radiator, but the pump looked fine with no endplay at all and I decided to trust my good luck.
But worse was yet to come.
So I took out the radiator out again, and then the pump. I cleaned all the rust inside the rotor chamber and the seal remnants.
21805
21806
Then I went to Pepe ´s workshop as he has a good press to extract the rotor.
We fitted the pump carefully in the press...
21807
And then the press blasted the whole pump body casting. A big chunk of steel hit my left elbow. It still hurts a lot but, thank God, does not seem to be broken.
21808
Having received a clear message that today is not the day to keep playing the fool in the shop, I ordered a new pump and went home to get some pain killers, a drink, and a good lunch followed by a homeric siesta.
Sorry to see this, and it was a good time to walk away for awhile.
Sorry for the set back. Good thing is you could order a new one.
Some old tractors a broken part like that turns into months or years of searching.
Discussion Starter · #127 ·
I think that some days our abilities to make handcrafts is somehow impaired. If you detect that you are in one of those days, best that you can do is read a good book while you listen to some music with a glass of your favourite drink. Anything is better than damaging something or getting harmed.
The water pump is easy to find. Unfortunately most of them are located in the UK and there is a considerable mess about VAT, custom taxes and some other expenses after Brexit, so you never know how much you are going to pay at the end of the day. Fortunately, european dealers are reacting and they now provide most of the spare parts that some months ago were only provided by british spare parts companies. I found one spare water pump in Netherlands and another one in the Spanish branch of a french dealer. This last one is the pump I bought. It will be here on Monday and I am glad about it because I hate the look of the tractor without the pump.
Discussion Starter · #128 ·
Not much done today because we went to enjoy the sunny day in Segovia for lunch.
However, I still managed to take the headlights apart, which are in a remarkable condition.
21812
21813
The blinkers were, and still are, mandatory. But they are not original and they have to be removed and the holes filled. I also removed the David Brown plate from the grille.
Discussion Starter · #129 ·
This is the grille after removing headlights, blinkers, emblem and hammering out the bumps.
21815
And this is the final result after treating the outer surface with paint remover and a wire brush disc.
21814
Discussion Starter · #130 ·
And this is the back side. It took me a whole morning to remove all the grime.
21824
I primed the inside but then I realized that I have to fill with weld the holes left by the blinkers.
Discussion Starter · #131 ·
I started cleaning the headlights. There was some rust inside and some nuts and screws refused to oblige. The mirrors were rather decayed. It was not chromed but covered in a silver hue. I went to the paint shop and found an accurate color to restore both.
21825
21827
Discussion Starter · #132 ·
The David Brown emblem on the grille also needed some attention. I polished the scratches and restored the paint. In this pic the letters had already been polished.
21828
21829
Discussion Starter · #133 ·
Then I started sanding the headlights hoods and rims. Now they are being primed. I will leave the cavities of the hoods as they are now, because the paint was in a good shape, there is something written with gold paint in them, and a good cleaning was all that was needed.
Discussion Starter · #134 ·
In the meantime, I have overhauled the hour meter. The dial glass was dirty and broken. The plates were dirty and damaged and the numbers were dirty and hardly visible. This is the hour meter with the paint stripped.
21843
The plates were restored as far as possible.
21844
21845
Discussion Starter · #135 ·
Then the meter was opened and the numbers discs restored with white paint.
21846
Then I carved a new dial glass out of a piece of acetate.
21847
Then the plates were masked and the meter primed.
Discussion Starter · #136 ·
Like this:
21848
Now all that remains is a good coat of urethane paint. I am gathering several items in order to paint them all together: the air filter, radiator bracket, headlights brackets and grille. And maybe some more like the steering column.
Great work on the little details!
Discussion Starter · #139 ·
And these are the battery supports cleaned and primed. It took me a lot of time to clean all the nooks and crannies!
21862
21863
Discussion Starter · #140 ·
The cooling pump was not the only leak in the cooling system. There was also another leak in the block drain tap. As a matter of fact, there were two different leaks in the tap.
21872
So I began looking for a replacement. But, first, I took a look to the parts manual and I discovered that originally there was no tap there but a winged plug. So I went shopping and found a suitable plug for 1,5 euros in a plumbers´ store. Not winged, but good enough for me.
21873
