I am not showing any charge on my Super C 6 volt system. The tractor has been sitting for years. I'm told it could be as simple as just needing re-polarized. I understand I need to jumper the BAT and GEN terminals on the regulator. The problem is my Regulator makes no note of which terminal is which. How can I tell this, or would anyone happen to know? This is my regulator here. Thanks!
-Lance
The GEN wire should go to A terminal on the genny, Batt could be any hot source, Id put a volt memter on the terminals and see which one is hot, that would be the batt.
I have a similar regulator and can look tomorrow morning on my way back home from PT and let you know what I find. There should be 3 letters on each of the connecting posts above the screw that tell you. If mine doesn't help you, just follow john's instructions
Should be layed out:
On the Left is armature
On the right from top to bottom, Field, Battery, Lights
You can give it a quick double check, but that's how the old and new of mine are layed out
