Is 3/8" chain (70 grade) sufficient to tie down a 3500 lb tractor for hauling or should one go up to 1/2". If you guys were buying new chain binders would you prefer the lever type or ratchet? This is all new to me so need some good info. Thanks
1/2 inch chain is always a good choice.
as for the binders?? We use both lever for lighter tractors and ratcheting for heavy tractors. Ratcheting will get real tight
Its not the size, its the strength of the chain. I use ratchet binders, since thats all I have, on everything from my Cub to my Ms, so its a personal choice on the binders, which ever works best for you. Only thing I use a strap on is my lawnmower and golfcart.
