Wow that looks good A little air and looks like it's ready to work!
You can run it off a temp gas tank until you get the other one back in working order. I Still have a tractor that I've been running for 2 years on a temp tank. Should really get it fixed up right.alleyyooper said:So far I've installed a new Igintion switch, battery, total carb tear down and soak with new gaskits and a genorator. Still needs one new rear tire, badly worn and weather checked. A new tube for the left front and when warm weather arrives the gas tank has to come off to get sealed up at the seam. Yes it has the telascopeing lift arm ends. The balls will fall out when not in use so remove them and put in the tool box.
:mrgreen: Al
