Hey y’all, I’m starting the restoration process on my tractor and am starting with electrical. I have placed an order for a new 6 volt alternator, OEM wiring harness, and a on/off keyed ignition switch, a solenoid( 6volt), and a distributor internals to replace the old ones. Now my question is, what else will I need to complete the electrics and can I reuse the coil that I took off the tractor or should I buy another, brand new coil?
I'd certainly use it if it works properly.
This is the question you asked
