gotta pull my fuel tank, alot of rust floating around. manual says to pull off the hood first. gonna try vinegar with nuts and bolts and shake, shake, shake. if i don't get good results, maybe radiator shop
I've cleaned several out like that......years ago. Never had the problem come back yet.
Too bad you don't have another tractor to strap the tank to a wheel and drive around for a bit.
Works good. (y)
i talked to a radiator shop, the gentleman there said liquid tide works good too instead of vinegar. he said maybe $100.00 to boil. $200.00 to seal also. hoping nuts and bolt do the trick.i loosened the two bolts at rear of tank and strap across hood. feels like i might be able to wiggle tank out without removing hood? wishful thinking? also found engine # it's 45-1290-G
You can jack.up one.side of the tractor, fasten your tank to it, and use a gas tank from another engine off a mower, log splitter, etc. Just strap it to the tractor. I ran a Farmall Cub for months like that with a tank off a B&S tiller engine while I was prepping the tractor for painting.
