HOW TO USE THIS:
All tractors have a serial tag. Most early tractors have a tag riveted to the fender or a tool box. 1939 and newer usually have the tag centered on the dashboard. With the two-tone tractors the tag was moved to the outer edges or the side of the dashboard on most. 930/1030 and newer have the tag located on the "firewall" around the clutch pedal. Engine serial numbers on all Racine tractors from the 1960's and prior are stamped into the back flange of the block usually in the area by the air cleaner except for cross-motor's which have the number stamped into the frame on the LH side around the area where water pump is. Rock Island tractors have an engine number stamped above the oil filter on the top rear of the side of the block. 1960's and newer the engine has a separate serial tag usually on the front right corner of the block where the injector pump is/would be. 1969 and newer also have a separate transmission tag on the RH side of the case. If your tag is missing, all Racine tractors 1960's and older can have the number recovered by checking the engine number providing the engine has never been changed. If your missing a tag on a Rock Island tractor there is no hope of recovering the number because the engines were numbered separate from the chassis but I can date the engines if you send me the number. There are many places to get reproduction serial tags, just make sure you order the correct one as they changed several times. Some places will also stamp the tag for you so make sure you have the correct serial number and model handy. For each letter and number series tractors there were numerous variations such as a DC-3, CH, 411, 411B, ect that signify different chassis types and also which fuel it ran on.
Year Serial Number
1912 100 - 890
1913 891 - 2495
1914 2496 - 2841
1915 2842 - 3690
1916 3691 - 7491
1917 7492 - 13284
1918 13285 - 22222
1919 22223 - 32840
1920 32841 - 42255
1921 42256 - 43942
1922 43943 - 45280
1923 45281 - 48412
1924 48413 - 51677
1925 51678 - 55918
1926 55919 - 62408
1927 62409 - 68403
1928 69004 - 69803
AI300101 - AI300150
AE300101 - AE300135
B300101 - B300190
TE300101 - TE301100
T300101 - T301150
A301151 - A324100
K306151 - K350100
1929 K300201 - K305200
T300201 - T301250
TE300201 - TE301200
A300201 - A305200
AE300201 - AE301200
L300201 - L368210
C300201 - C313285
1930 C300301 - C310331
L300301 - L364308
1931 C300401 - C343497
L300401 - L335413
1932 C300501 - C308519
L300501 - L304572
1933 C300601 - C302650
L300601 - L303698
1934 C300701 - C302733
L300701 - L310750
1935 C300801 - C362896
L300801 - L322818
1936 C300901 - C3119136
L300901 - L338922
RC300901 - RC335900
1937 C400001 - C4100671
L400001 - L4449022
RC400001 - RC402050
*Rock Island tractors for the following years include R, V & VA series tractors
1938 4200001 - 4211575 Racine built
4200001 - 4206200 Rock Island built
1939 4300001 - 4304952 Racine built
4300001 - 4302250 Rock Island built
1940 4400001 - 4408523 Racine built
4400001 - 4405903 Rock Island built
1941 4500001 - 4517367 Racine built
4500001 - 4510245 Rock Island built
1942 4600001 - 4613281 Racine built
4600001 - 4613783 Rock Island built
1943 4700001 - 4707541 Racine built
4700001 - 4702618 Rock Island built
1944 4800001 - 4818502 Racine built
4800001 - 4807172 Rock Island built
1945 4900001 - 4919308 Racine built
4900001 - 4911191 Rock Island built
1946 5000001 - 5004556 Racine built
5000001 - 5016946 Rock Island built
1947 5100001 - 5110689 Racine built
5100001 - 5116641 Rock Island built
1948 5200001 - 5226594 Racine built
5200001 - 5223240 Rock Island built
1949 5300001 - 5331298 Racine built
5300001 - 5317004 Rock Island built
1950 5400001 - 5425562 Racine built
5400001 - 5408987 Rock Island built
1951 5500001 - 5525620 Racine built
5500001 - 5513216 Rock Island built
1952 5600001 - 5621381 Racine built
5600001 - 5609189 Rock Island built
1953 5622406 - 5622744 Racine built
8022746 - 8032411 Racine built
5750001 - 5756831 Rock Island built
1954 8035001 - 8043195 Racine built
6011500 - 6014270 Rock Island built
1955 8060001 - 8069183 Racine built
6038001 - 6040248 Rock Island built
1956 8080001 - 8087136 Racine built
6050301 - 6068999 Rock Island built
1957 8100001 - 8108600 Racine built
6075001 - 6089800 Rock Island built
1958 8120001 - 8131350 Racine built
6095001 - 6115200 Rock Island built
1959 8140001 - 8154999 Racine built
6120001 - 6140000 Rock Island built
1960 8160001 - 8165796 Racine built
6144001 - 6158100 Rock Island built
1961 8168801 - 8180843 Racine built
6162601 - 6172550 Rock Island built
(last year of Rock Island production)
1962 8190001 - 8203550
1963 8208001 - 8226500
1964 8229001 - 8251840
1965 8253501 - 8278502
1966 8279001 - 8305500
1967 8306501 - 8332100
1968 8332101 - 8356250
1969 8356251 – 8376150
1970 8650001 - 8673000
1971 8674001 – 8691756
1972 8691801 - 8712000
1973 8712001 - 8736600
1974 8736601 - 8759600
1975 8770001 - 8796500
1976 8797501 - 8809949
1977 8810601 - 8821441
1978 8830001 - 8838826
1979 8840001 - 8851892
1980 9901991 - 9909713
1981 9910025 - 9918560
1982 9918830 - 9924694
1983 9924700 - 9931357
1984 9931800 - 9938080
1985 9938100 - 9941572
1986 9941573 - 9945447
1987 9945448 - 9949622
1988 JJA0001501 - JJA0009956
1989 JJA0009957 - JJA0020438
1990 JJA0020439 - JJA0031763
1991 JJA0031764 - JJA0040513
1992 JJA0040514 - JJA0046419
Trying to identify what tractor I have. It is square nose case with missing tag by instrument cluster. Engine serial number reads as follows: 112N02346. Serial number is stamped vertical by oil filter at rear of block -Ed
