Got the old 560 fired up today after it setting for a couple years. Checked points(cleaned), wires, and so on. After it started it had a bad miss. Started pulling plug wires. Cyl 2 and 5 weren't firing right. Replaced the 2 plugs and it straightened out. So now the big question,......... when you pull the plug wire off just a short distance, enough to get it to arc on a missfiring plug, and the engine smooths out, .....put it back on the plug and it misses again........ can someone explain why
